Windows Based VAG/VAS Emulator
Version: Release xx.x.x
Dealer/Shop Name:
Workshop Code: 000 00000
Diagnostic Trouble Code Report
Sunday,09,July,2006,11:44:30
VIN Number: WVWRU73C57Exxxxxx License Plate: ABC 1234
Mileage: 99991 Repair Order: R060709-1234
Control Module Part Number: 03H 906 032 B
Component and/or Version: P3.6-FSI-LEV2   G00 8744
Software Coding: 0000175
Work Shop Code: WSC 05311
7 Faults Found:
008851 -  Fuel Pressure Regulator Valve (N276): Mechanical Malfunction
               P2293 - 002 - Lower Limit Exceeded - Intermittent - MIL ON
                    Fault Status: 10100010
                    Fault Frequency: 8
                    Mileage: 3641 km
                    Date: 2006.06.30
                    Time: 08:10:39
                    RPM: 626 /min
                    Load: 44.7 %
                    Temperature: 86.0�C
                    Temperature: 45.0�C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 13.716 V
000768 -  Random/Multiple Cylinder Misfire Detected
               P0300 - 001 - Upper Limit Exceeded - MIL ON
                    Fault Status: 11100001
                    Mileage: 3641 km
                    Date: 2006.06.30
                    Time: 08:10:41
                    RPM: 713 /min
                    Load: 39.6 %
                    Speed: 2.0 km/h
                    Temperature: 82.0�C
                    Temperature: 49.0�C
                    Voltage: 13.462 V
000769 -  Cylinder 1: Misfire Detected
               P0301 - 001 - Upper Limit Exceeded - MIL ON
                    Mileage: 3641 km
                    Date: 2006.06.30
                    Time: 08:10:42
                    RPM: 736 /min
                    Load: 40.8 %
                    Speed: 2.0 km/h
                    Temperature: 82.0�C
                    Temperature: 49.0�C
                    Voltage: 13.589 V
000771 -  Cylinder 3: Misfire Detected
               P0303 - 001 - Upper Limit Exceeded - Intermittent - MIL ON
                    Fault Status: 10100001
                    Mileage: 3641 km
                    Date: 2006.06.30
                    Time: 08:11:25
                    RPM: 1550 /min
                    Load: 22.0 %
                    Speed: 34.0 km/h
                    Temperature: 86.0�C
                    Temperature: 40.0�C
                    Voltage: 13.970 V
000770 -  Cylinder 2: Misfire Detected
               P0302 - 001 - Upper Limit Exceeded - Intermittent - MIL ON
                    Mileage: 3641 km
                    Date: 2006.06.30
                    Time: 08:11:25
                    RPM: 1550 /min
                    Load: 22.0 %
                    Speed: 34.0 km/h
                    Temperature: 86.0�C
                    Temperature: 40.0�C
                    Voltage: 13.970 V
000773 -  Cylinder 5: Misfire Detected
               P0305 - 002 - Lower Limit Exceeded - Intermittent
                    Mileage: 4275 km
                    Date: 2006.07.07
                    Time: 12:12:53
                    RPM: 2369 /min
                    Load: 29.4 %
                    Speed: 69.0 km/h
                    Temperature: 87.0�C
                    Temperature: 36.0�C
                    Voltage: 13.970 V
000312 -  Oxygen (Lambda) Sensor B1 S2: Signal too High
               P0138 - 001 - Upper Limit Exceeded - Intermittent
                    Fault Status: 00100001
                    Mileage: 4276 km
                    Date: 2006.07.07
                    Time: 14:02:40
                    RPM: 572 /min
                    Load: 27.8 %
                    Speed: 3.0 km/h
                    Temperature: 84.0�C
                    Temperature: 51.0�C
                    Voltage: 13.589 V
