Online Demo / Manual - Advanced
Measuring Blocks
This function expands on the
Measuring
Blocks function and lets you select up to 12 measuring values from as
many as 12 different groups from a selection dialog that shows the
contents of the measuring values. This function is available only when
a label file
exists for the control module being accessed.
The Advanced Measuring Blocks now include a
[ Turbo ] button and the ability to save the list of selected
items to a file and retrieve it later. To save a set of items, click on
the VAG-COM logo found on the top left corner of the item selection
window, then select "Save selection to file". Give the file a name and
specify the directory if desired. To load a set of previously saved
items, click on the VAG-COM logo found on the top left corner of the
item selection window, then select "Load selection from file". Locate
the previously saved file and click [ Open ].
Acceleration Measurement
When you have one or more measuring group
with speed (km/h) in it, clicking on [Acceleration] will bring up
the Acceleration Measurement window, which allows you to enter start and
stop speeds and distances. After entering the values you want to
measure, click [Start] and do your testing. When complete, click
on [Save] to save a copy of your results to your C:\Program
Files\VAG-COM\Logs directory.
Sample Rate:
The frequency that the data is updated
is determined by the controller in the vehicle. Selecting a
greater number of different Groups will result in slower
sampling. This function does not currently support the
[Turbo Mode] that is found in Measuring Blocks when reading
Engine controllers that run KWP-2000.
You can
[Log] the data from the
Advanced Measuring Blocks screen. For more information see the
Data Logging page.
[VAG-Scope]
is a plug-in for VAG-COM
that allows you to graph Measuring Group Information and display
customizable virtual gauges. For more information, see the VAG-Scope page.
Use
[Done, Go Back] to return to
the Controller Information screen.
Warning!
If you wish to observe real-time data while driving the car, please use
a second person! Let one drive while the other observes the data,
making sure the person holding the PC is not in front of an active
airbag!
Note: You may also want to
try the Measuring Blocks
function, which accesses the same data but in a different
format.
This function is not available in shareware mode.
Measuring Blocks
