Supported Codes function. Only
some KWP2000/CAN/UDS control modules support this function
and there is no way to tell which have this capability
without trying the function. VCDS can show all
DTC and Failure Mode combinations that a control module is capable of
detecting, including the current status of each.
You can sort the results by selecting the
radio buttons on the right side of the screen.
Use
[OK] to return to
the Controller Info / Select Function screen.
Note: On the Open Controller
screen, the Supported Codes button will appear in place of
the Single Reading function
in modules that support it, since the two functions are
mutually exclusive.
