Loading
            Product Information
                Function Chart
Function Chart / Feature Comparison
  VAS-505x   $5-15k
"New" VAS Function Number VCDS-Lite   Shareware
   $0.00 - $99
VCDS    Full Version
 $249 - $699
Function Number / Name
00  Auto-Scan 1001.01 Registered Version Only Yes
01  Control Unit Info   Yes Yes
02  Read Fault Codes 004.01 Limited unless Registered Yes
03  Output Tests  005 Registered Version Only Yes
      Selective Output Tests 005 No Yes
04  Basic Settings 006 Registered Version Only Yes
05  Clear Fault Codes  004.10 Yes Yes
06  Close Controller 022 Yes Yes
07  Code Module 007 (Service 1A)
008 (Service 22)
Yes Yes
      Code Slave Modules 007 (Service 1A)
008 (Service 22)
No Yes
08  Measuring  Blocks 010.02 (KW1281)
011
09  Single Reading 010.01 Yes Yes
10  Adaptation 012
014 (long)
Limited unless registered Yes
11  Login
      (called Coding II
     under KWP-2000)
015.01 Yes Yes
15  View Readiness 020.01 Yes Yes
16  Security Access 015.02 Registered Version Only Yes
18  Supported Codes   No Yes
33  Generic OBD-II   No Yes
Freeze-Frame Data   Registered Version Only Yes
Dual K-Line Support   Yes Yes
7-Digit PINs (VAS only) 020.07 Registered Version Only Yes
Code Database current through MY 2012   Current through ~2006 Yes
Diagnostics via direct CAN connection   No Yes
(with CAN Interface)
Transport Mode (VAS Only) 1001.03 (on)
1001.04 (off)
No Yes
(with HEX+CAN Interface)
Advanced Measuring Values   No Yes
Guided Readiness Scripts   No Yes
Support for Dual ECUs   No Yes
Data Logging
(Factory tools cannot do this!)
HighSpeed DataLogging
  No Yes
(with HEX Interface)
Real-Time Graphs
Real-Time Gauges
Graphic TDI Timing Checker
Control Module Finder
  Yes Yes
Automated Service Reset
(SRI)
  No Yes
GeKo/Fazit on-line access to Immobilizer Codes and Component Protection   No No
Ross-Tech customer Arthur Emerson campaigning
his TT in SCCA Pro-Solo
            Product Information
                Function Chart
