Search:
                Online Demo / Manual -
Supported Codes
Corresponds to VAS 5051/5052 function 18
Supported Codes function.   On the latest control modules which have this capability, VAG-COM can show all DTC and Failure Mode combinations which a control module is capable of detecting, including the current status of each.
You can sort the results by selecting the radio buttons on the right side of the screen.
Use [OK] to return to the Controller Info / Select Function screen.
Note: On the Open Controller screen, the Supported Codes button will appear in place of the Single Reading function in modules that support it, since the two functions are mutually exclusive.
Shareware Limitation(s):  Not available in shareware mode..
Supported Codes
