Groups 130-137:  Engine cooling
130
Map cooling (coolant filling), Short trip
Temperature
Engine outlet
Temperature
Radiator outlet
Duty cycle
Thermostat
Result
[�C]
[�C]
Text:
Test ON/ Test OFF/
 Syst. OK/ Syst. Not OK
131
Map cooling
Temperature
Engine outlet
Temperature
Engine outlet (specified)
Temperature
Radiator outlet
Duty cycle
Thermostat
[�C]
[�C]
[�C]
132
Map cooling
Temperature
Radiator outlet (specified)
Temperature difference
Engine and radiator outlet
Heater pre-run potentiometer
Status cooling
[�C]
[�C]
xxxxxxxx
│││││││└ Error │││││││    in system ││││││└ Thermostat-
││││││  actuation
││││││  active
│││││└ Cooling van
│││││   triggering active
││││└Control deviation
││││0 > specified temp.
││││1 < specified temp
│││└ Fan stage 2 active
││└ Fan stage 1 active
│└ not used
└ not used
1: Description fulfilled
0: Description not fulfilled
133
134
Temperature
Oil temperature
Ambient temperature
Intake air temperature
Engine outlet temperature
[�C]
[�C]
[�C]
[�C]
135
Coolant fan control, short trip
Temperature
Duty cycle
Coolant fan actuation 1
Duty cycle
Coolant fan actuation 2
Result
[�C]
Text:
Test ON/ Test OFF/
136
Relay for coolant fan actuation
Relay 1
Relay 2
Relay 3
Relay 4
ON / OFF
ON / OFF
ON / OFF
ON / OFF
137
A/C requirements
AC-inlet
Compressor
High pressure switch or
Pressure of A/C system
Fan request from A/C system
ON / OFF
ON / OFF
ON / OFF or
[bar]
