Groups 110 - 119:  Load Registration & Boost Pressure Control
110
Load, full load enrichment
RPM
Coolant temperature
Average injection time
Throttle valve angle (potentiometer)
[1/min]
[�C]
[ms]
111
Boost pressure control
Adaption value boost pressure control RPM range 1
Adaption value boost pressure control RPM range 2
Adaption value boost pressure control RPM range 3
Adaption value boost pressure control RPM range 4
112
Exhaust gas temperature
Exhaust gas temperature Bank 1
Enrichment factor
sensor Bank 1
Exhaust gas temperature Bank 2
Enrichment factor
sensor Bank 2
[�C]
[�C]
113
Last
RPM
Last
Air pressure
[1/min]
[mbar]
114
Specified load without correction
Specified load after  correction
Actual load
Duty cycle
Boost pressure valve
115
RPM
Last
Boost pressure specified value
Boost pressure actual value
[1/min]
[mbar]
[mbar]
116
RPM
Correction factor fuel
Correction factor coolant temperature
Correction factor intake air temperature
[1/min]
117
RPM
Gas pedal position
[1/min]
[mbar]
118
RPM
Intake air temperature
Duty cycle boost pressure control valve
Boost pressure before throttle valve
[1/min]
[�C]
[mbar]
119
RPM
Actual adaption value boost pressure control valve
[1/min]
[mbar]
