Groups 101 - 109: Fuel Injection
101
Fuel injection
Systems with Air mass measurement
RPM
Last
Mean injection time
(at deceleration = 0)
Air mass
[1/min]
[ms]
[g/s]
101
Fuel injection
Systems with intake manifold pressure measurement
RPM
Last
Mean injection time
Intake manifold pressure
[1/min]
[ms]
[mbar]
102
Fuel injection
RPM
Coolant temperature
Intake air temperature
Mean injection time
[1/min]
[�C]
[�C]
[ms]
103
Air-shrouded fuel injectors, short trip
RPM
Air mass idle air control
LFR-Offset adaptation
Results
[1/min]
[g/s]
[n]
Test ON/Test OFF/
l injector OK /l injector not OK
104
Start adaptation values
Start engine temperature
Temperature adaptation factor 1
Temperature adaptation factor 2
Temperature adaptation factor 3
[�C]
105
Cylinder shut off
RPM (actual)
Last
Coolant temperature
Shut-off
[U/min]
[�C]
Text:
ON/OFF[1]
106
107
Lambda regulation, short trip
RPM
Lambda regulation Bank 1
(average value)
Lambda regulation Bank 2
(average value)
Result
[1/min]
Text
Test ON/ Test OFF/
 Syst. OK/ Syst. Not OK
108
109
[1] ON = Cylinder shut-off active; OFF = Cylinder shut-off  not active
