090
Camshaft
adjustment Intake
RPM
Adjustment
Adjustment
Bank 1
Adjustment
Bank 2
[1/min]
Text
ON/OFF
[�KW]
[�KW]
090
RPM
Adjustment
Adjustment
Bank 1
Adjustment
Bank 2
[1/min]
Text
ON/OFF
[�KW]
[�KW]
090
RPM
Duty
cycle
Adjustment
specified
Adjustment
actual
[1/min]
[�KW]
[�KW]
091
Camshaft
adjustment Intake Bank 1
RPM
Last
Adjustment
Adjustment
[1/min]
Text
ON/OFF
[�KW]
091
Continuous
camshaft adjustment, Intake Bank 1
RPM
Duty
cycle
Adjustment
specified
Adjustment
actual
[1/min]
[�KW]
[�KW]
092
RPM
Last
Adjustment
Adjustment
[1/min]
Text
ON/OFF
[�KW]
092
RPM
Duty
cycle
Adjustment
specified
Adjustment
actual
[1/min]
[�KW]
[�KW]
093
Camshaft
adaption values Intake
2-Bank
Systems
RPM
Last
Phase
position [1] Bank 1[2]
Phase
position Bank 2
[1/min]
[�KW]
[�KW]
093
Phase
position intake
Bank
Phase
position intake
Bank
Phase
position exhaust Bank 1
Phase
position exhaust Bank 2
[�KW]
[3]
[�KW]
[�KW]
[�KW]
094
RPM
Camshaft
adjustment
Test
result Bank 1
Test
result Bank 2
[1/min]
Text:
Camshaft position ON / Camshaft position
Test
ON/ Test OFF/
Syst.
OK/ Syst. Not OK
Test
ON/ Test OFF/
Syst.
OK/ Syst. Not OK
094
RPM
Phase
position intake
Test
result Bank 1
Test
result Bank 2
[1/min]
[�KW]
Test
ON/ Test OFF/
Syst.
OK/ Syst. Not OK
Test
ON/ Test OFF/
Syst.
OK/ Syst. Not OK
095
Intake
manifold change-over
Single
step change-over
Engine
RPM
Last
Coolant
temperature
[1/min]
[�C]
Text:
ein/aus
095
Intake
Multi-step
change-over
Engine
RPM
Last
Coolant
temperature
[1/min]
[�C]
Text:
Off
/step 1/step 2
096
RPM
Camshaft
adjustment
Test
result Bank 1
Test
result Bank 2
[1/min]
Text:
Test
ON/ Test OFF/
Syst.
OK/ Syst. Not OK
Test
ON/ Test OFF/
Syst.
OK/ Syst. Not OK
096
RPM
Phase
position exhaust
Test
result Bank 1
Test
result Bank 2
[1/min]
[�KW]
Test
ON/ Test OFF/
Syst.
OK/ Syst. Not OK
Test
ON/ Test OFF/
Syst.
OK/ Syst. Not OK
097
Intake
air change-over / Snow flap
RPM
Last
Temperature
/ Pressure
Intake
air change-over
[1/min]
[�C]/[mbar]
ON/
098
Continuous
camshaft adjustment Exhaust Bank 2
RPM
Duty cycle
Adjustment
specified
Adjustment actual
[1/min]
[�KW]
[�KW]
