070
Fuel
tank venting and valve testing, short trip
Opening
degree fuel tank ventilation
Lambda
regular/
diagnostic
value with active
diagnose
Idle
air control valve / diagnostic value with active diagnose
Result
/ [%] / [g/sec]
Test
ON/ Test OFF/
Fuel tank ventilation OK/ Fuel tank ventilation not OK.
071
Fuel
tank leak test, short trip
Condition
reed contact
DTC
Test
status
Result
Text
Reed
Open / Reed Closed
Text
Small
leak/large leak
System
test/measurement/
measurement end
Test
ON/ Test OFF/
Abort
Syst. OK/ Syst. Not OK
072
Tank
leak test
073
074
EGR
regulator solenoid adaption
Null-Position
Max.
stop
Current
potentiometer value
Text
[V]
[V]
[V]
Leak
detection pump runs/ LDP OK/ ERROR
075
EGR,
short trip
Systems
with Temp.-sensor
Engine
RPM
EGR-Temp.
Sensor
EGR
temperature difference
Result
[1/min]
[�C]
[�C]
Test
ON/ Test OFF/
Syst.
OK/ Syst. Not OK
075
EGR,
short trip
Systems
with intake manifold pressure sensor
Engine
RPM
Intake
manifold pressure
Intake
manifold pressure difference
Result
[1/min]
[mbar]
[mbar]
Test
ON/ Test OFF/
075
EGR,
for map adaption short trip
Systems
Pressure
difference diagnostics EGR phase 1 and 2
Pressure
difference diagnostics EGR phase 2 and 3
Pressure
difference diagnostics EGR phase 1 and 3
Result
[hPa]
[hPa]
[hPa]
Test
ON/ Test OFF/
076
EGR
for pressure systems
Engine
RPM
Intake
manifold pressure
Opening
degree (U/Uref)
EGR
potentiometer
Duty
cycle EGR valve
[1/min]
[mbar]
076
EGR
for air mass system
Engine
RPM
Last
Opening
degree (U/Uref)
EGR
potentiometer
Duty
cycle EGR valve
[1/min]
076
EGR
map adaption
Actual
EGR value � potentiometer without offset
Correction
factor in the upper opening range
Correction
factor in the lower opening range
[V]
Test
OFF / Leak detection pump runs/ LDP OK/ ERROR
077
Test
secondary air injection system, short trip, Bank 1
Systems with conventional oxygen sensor
RPM
Engine
air mass
Air
mass secondary air injection system
Result
[1/min]
[g/sec]
[g/sec]
Test
ON/ Test OFF/
Abort
077
Test
Systems with linear oxygen sensor
RPM
Engine
air mass
relative
Air mass
Result
[1/min]
[g/sec]
Test
ON/ Test OFF/
Abort
Syst.
OK/ Syst. Not OK
078
Test
Bank 2
RPM
Engine
air mass
Air
Result
[1/min]
[g/sec]
[g/sec]
Test
ON/ Test OFF/
Abort
078
Test
secondary air injection system, short trip, Bank 2
RPM
Engine
air mass
Relative
air mass
Result
[1/min]
[g/sec]
Test
ON/ Test OFF/
Abort
079
