Groups 050 - 059:  Engine Speed Control
050
RPM increase
Systems without separation for rear window defroster /A/C readiness
RPM actual value
RPM specified value
Rear window defroster/
Request for A/C
A/C compressor
[1/min]
[1/min]
Text
ON/ OFF
Text
ON/ OFF/ decrease
050
RPM increase
Systems with separation for rear window defroster /A/C readiness
RPM actual value
RPM specified value
Request for A/C
A/C compressor
[1/min]
[1/min]
Text
ON/ OFF
Text
ON/ OFF/ decrease
051
RPM, shift initiations
RPM actual value
RPM specified value
Driving range (only for automatic transmission)
Supply voltage
[1/min]
[1/min]
0-6
(Idle, driving ranges 1-6)
[V]
052
RPM increase
Not used
052
RPM increase
RPM (actual value)
RPM (specified value)
A/C readiness
[1/min]
[1/min]
Text
ON/OFF
Text
ON/OFF
053
RPM increase based on generator load
RPM (actual value)
Voltage
Generator load
[1/min]
[1/min]
[V]
054
Closed throttle position switch
RPM
Operating conditions
Throttle valve angle (Potentiometer)
[1/min]
(LL, TL, VL, SA, BA)
054
Closed throttle position switch  for E-Gas-systems
RPM
Sensor 1 for accelerator pedal position
[1/min]
055
Idle air control
RPM
Idle air control
Current learning value for idle air control
[1/min][1]
[[2]]
[[3]]
x0xxx  [4]
││││└─A/C
││││    compressor ON
│││└──Driving
│││       range selected
││└───A/C readiness,
││          rear window
││          defroster
││         ON
│└────always0
└Steering to stop
055
Idle air control
RPM
Idle air control
Learning value for idle air control
[1/min]
[[5]]
[[6]]
xxxxx  8
││││└─A/C
││││    compressor ON
│││└──Driving
│││       range selected
││└─── A/C readiness
││          ON
│└──── rear window
             defroster ON
└ Steering to stop
056
Idle air control
RPM (actual value)
Idle air control valve
[1/min]
[1/min]
[[7]]
x0xxx  8
││││└─ A/C
││││    compressor ON
│││└── Driving
│││       range selected ││└─── A/C readiness,
││          rear window
││          defroster
││         ON
│└────always 0
└ Steering to stop
056
Idle air control
RPM (actual value)
[1/min]
[1/min]
[[8]]
xxxxx  [9]
││││└─ A/C
││││    compressor ON
│││└── Driving
│││       range selected
││          rear window │└──── defroster
└ Steering to stop
057
Idle air control, pressure signal A/C compressor
RPM (actual value)
A/C compressor
Duty cycle pressure receiver
[1/min]
[1/min]
Text:
ON/OFF/decreasing
058
RPM
Load
Engine bearing 1 right
Engine bearing 2 left
[1/min]
ON/OFF
ON/OFF
059
[1]
[2] The fitting unit depends on the applicable system
[3] The fitting unit depends on the applicable system
[4] Condition fulfilled = 1; Condition not fulfilled =0
[5] The fitting unit depends on the applicable system
[6] The fitting unit depends on the applicable system
[7] The fitting unit depends on the applicable system
[8] The fitting unit depends on the applicable system
[9] Condition fulfilled = 1; Condition not fulfilled = 0
