Groups
030-049: Mixture Control, O2S Heating, Catalytic Converter
030
Oxygen sensor, status
2-bank
systems
Bank 1, sensor 1
Bank 1, sensor 2
Bank 2, sensor 1
Bank 2, sensor 2
xxx
4
││└─Control
active
│└──Sensor
ready
└───Sensor
heater ON
xxx
Control active
Sensor ready
Sensor heater ON
xxx
4
Control active
Sensor ready
Sensor heater ON
xxx
4
Control active
Sensor ready
Sensor heater ON
030
1-
bank systems
Bank 1, sensor 1
Bank 1, sensor 2
xxx
4
Control active
Sensor ready
Sensor heater ON
xxx
4
Control active
Sensor ready
Sensor heater ON
031
Oxygen
sensor voltage
2-
bank systems
Bank 1, sensor 1
Bank 1, sensor 2
Bank 2, sensor 1
Bank 2, sensor 2
[V]
[V]
[V]
[V]
031
Oxygen sensor voltage
1-
bank systems
Bank 1, sensor 1
Bank 1, sensor 2
[V]
[V]
031
Linear
oxygen sensors
2-
bank systems
Lambda
actual value
Bank
Lambda
specified value Bank 1
Lambda
actual value
Bank
Lambda
specified value
Bank 2
031
Linear
oxygen sensors
1-
bank systems
Lambda
actual value
Bank
Lambda
specified value
Bank 1
032
Oxygen
sensors learning values (maximum value)
2-
bank systems
Bank
1, sensor 1, idle
Bank
1, sensor 1, partial load
Bank 2, sensor 1, idle
Bank
2, sensor 1, partial load
032
Oxygen
1-
bank systems
Bank
1, sensor 1, idle
Bank
033
Lambda
control value
2-
bank systems
Bank
1, control value
Bank 1, Oxygen sensor voltage
Bank
2, control value
Bank 2, knock sensor voltage
[V]
[V]
033
Lambda
control value
1-
bank systems
Bank
1, control value
[V]
033
Linear
oxygen sensor control value
2-
bank systems
Bank
1, control value
Bank
1, sensor voltage before cat. converter of a broad band sensor
Bank
2, control value
Bank
2, sensor voltage before cat. converter of a broad band sensor
[V]
[V]
034
Oxygen
sensor aging test Bank 1 or Bank 3 before catalytic converter, short
trip
RPM
Exhaust
gas / cat. converter temperature
Length
of period
Result
[1/min]
[�C]
[s]
Text:
Test
ON/Test OFF/
B1-S1 OK/B1-S1 not OK
or:
B3-S1
OK /B3-S1 not OK
034
Oxygen
sensor aging test Bank 1 or Bank 3 before cat. converter for linear
oxygen sensors. short trip
RPM
Exhaust
Dynamic
factor
Result
[1/min]
[�C]
Text:
Test
ON/Test OFF/
B1-S1
OK/B1-S1 not OK
or
B3-S1
OK ./B3-S1 not OK
035
Oxygen
sensor aging test Bank 2 or Bank 4 before cat. converter, short trip
2-bank
systems
RPM
Exhaust
Length
of period
Result
[1/min]
[�C]
[s]
Text:
Test
ON/Test OFF/
B2-S1
OK/B2-S1 not OK
or
B4-S1
OK/B4-S1 not OK
035
Oxygen
sensor aging test Bank 2 or Bank 4 before cat. converter for linear
oxygen sensors, short trip
2-
bank systems
RPM
Exhaust
Dynamic
factor
Result
[1/min]
[�C]
Text:
Test
ON/Test OFF/
B2-S1 OK /B2-S1 not OK
or:
B4-S1
OK/B4-S1 not OK
035
Oxygen
sensor aging test Bank 2 before cat. converter
1-
bank systems
036
Oxygen
sensor readiness after cat. converter, short trip
2-
bank systems
Bank
1, sensor 2
Result
Bank
2, sensor 2
Result
Sensor
voltage
Text:
Test
ON/Test OFF/
B1-S2 OK/B1-S2 not OK
or:
B3-S2
OK/B3-S2 not OK
Sensor
voltage
Text:
Test
ON/Test OFF/
B2-S2
OK/B2-S2 not OK
or:
B4-S2
OK/B4-S2 not OK
036
Oxygen
1-
bank systems
Bank
1, sensor 2
Result
Sensor
voltage
Text:
Test
ON/Test OFF/
B1-S2
OK./B1-S2 not OK.
037
Oxygen
sensors, short trip
Last
Bank
1: Oxygen sensor voltage after cat. converter
Bank
1: TV shift
Result
[V]
[ms]
Text:
Test
ON/Test OFF/
Sys.
OK/Sys. not OK
037
Linear
Last
Bank
Bank
1: D Lambda
Result
[V]
Text:
Test
ON/Test OFF/
Sys. OK/Sys. not OK
038
Oxygen
sensors, short trip
2-
bank systems
Last
Bank
2: Oxygen sensor voltage after cat. converter
Bank
2: TV shift
Result
[V]
[ms]
Text:
Test
ON/Test OFF/
Sys
OK/Sys. not OK
038
Linear
2-
bank systems
Last
Bank
Bank
2: D Lambda
Result
[V]
Text:
Test
ON/Test OFF/
Sys OK/Sys. not OK
038
Oxygen
sensors
1-
bank systems
Not
used
039
Sensor
exchange after cat. converter short trip
Air
mass
Bank
1: sensor voltage
Bank
2 sensor voltage
Result
[g/s]
[V]
[V]
Text:Test
ON/Test OFF/
Sys
OK/Sys. not OK
040
Oxygen
sensor heaters resistor Combined
wires and
heaters
2-
bank systems
Heater
resistor
Condition
Heater
resistors
Condition
Banks
1+2, sensor 1
[Ω]
Text:
Heater
before cat. ON/ Heater before cat. OFF
Banks
1+2, sensor 2
[Ω]
Text:
Heater
040
1-
bank systems
Not
used
041
Oxygen
sensor heater
1-
bank systems
Resistor
Condition
or duty cycle
Resistors
Condition
Bank
1, sensor 1
[Ω]
Text:
Heater
or:
sensor
1 [%]
Bank
1, Sensor 2
[Ω]
Text:
Heater
after cat. ON/ Heater after cat. OFF
042
Oxygen
sensor heaters, separate
wires of heaters
2-
bank systems
Resistor
Condition
or duty cycle
Resistors
Condition
Bank
2, Sensor 1
[Ω]
Text:
Heater
or:
Sensor
1 [%]
Bank
2, Sensor 2
[Ω]
Text:
Heater
043
Oxygen
sensor ageing after cat. converter, linear oxygen sensors, short
trip
Bank
RPM
Exhaust
Result
[U/min]
[�C]
[V]
Text:
Test
ON/Test OFF/
B1-S2
OK/B1-S2 not OK
Or:
B3-S2
OK/B3-S2 not OK
044
Oxygen
sensor ageing after cat. converter, short trip
Bank
RPM
Exhaust
Result
[U/min]
[�C]
[V]
Text
Test
ON/Test OFF/
B2-S2 OK /B2-S2 not OK
Or:
B4-S2
OK/B4-S2 not OK
044
1-bank
systems
045
NOx
memory cat. converter Bank 1, short trip
NOx
memory cat. converter Bank 2
Factor
memory entry NOx
Result
Factor
memory entry NOx
Result
Text:
Test
ON/Test OFF/
Sys. OK/Sys. not OK
Text:
Test
ON/Test OFF/
Sys. OK/Sys. not OK
046
Cat.
converter conversion test Bank 1 or Bank 3, short trip
RPM
Cat.
Measuring
value cat. Converter conversion
Result
[1/min]
[�C]
Text:
Test
ON/Test OFF/
Cat B1 OK/
Cat B1 not OK
or:
Cat
B3 OK/
Cat B3 not OK
047
Cat.
converter conversion test Bank 2 or Bank 4, short trip
2-Bank-Systems
RPM
Cat.
Measuring
Result
[1/min]
[�C]
Text:
Test
ON/Test OFF/
Cat B2 OK/
Cat B2 not OK
or:
Cat
B4 OK/
Cat B4 not OK
047
Cat.
1-Bank-Systems
Not
used
048
Thermal
cat. converter diagnosis
Bank 1, short trip
Operating
system BDE
Number
of test steps
Exothermal
temperature increase
Result
[K]
Text:
Test
ON/Test OFF/
Sys.
OK/Sys. not OK
049
Thermal
Bank 2, short trip
Operating
system BDE
Number
of test steps
Exothermal
Result
[K]
Text:
Test
ON/Test OFF/
Sys. OK/Sys. not OK
