Groups 001 - 009 General Engine Data
001
General
2 Bank systems
RPM
Engine coolant temperature
Lambda control value Bank 1
Lambda control value Bank 2
[1/min]
[�C]
1-Bank-Systems
(Injection adjustment)
Adjustment requirements for basic setting
xxxxxxxx
│││││││└Coolant │││││││ temp. > 80�C
││││││└─RPM < ││││││ 2000 1/min
│││││└──Throttle │││││ closed
││││└───Lambda- ││││ control: OK
│││└────Idle │││ switch closed
││└─────A/C compr. ││ OFF
│└──────Cat temp.
│ reached
└───────no DTC stored in memory
1: Conditions attained
0: Conditions not attained
002
Systems with Mass Airflow Sensor
Load
Mean injection time
Air mass
[ms]
[g/s]
Systems with intake manifold pressure sensor
Intake manifold pressure
[mbar]
003
Throttle valve angle (Potentiometer)
Ignition angle (actual)
[�KW]
004
Voltage
Cooling temperature
Intake air temperature
[V]
005
Speed
Operating condition
[km/h]
Text
(Idle, partial load, full load, SA, BA)[1]
006
Altitude correction[2]
007
General BDE
Mass Airflow Sensor
Pressure bake booster
008
Condition brake
Supply voltage
Condition vacuum pump for brake
activated / not activated
Pump ON / Pump OFF
009
[1] Idle, partial load, full load, deceleration fuel shut-off, acceleration enrichment
[2] Relative to reference level; 0% = 0 m; -100% = 10000 m
