Product
Information
Interfaces
12V Power Adapter Warning
12V Power Adapter
Warning
It has come
to our attention that there are some cheap
"universal" 12V laptop adapters which should NEVER be used while scanning a car.
One example is Radio Shack part number 237-1827:
Do not use
this Adapter! On at least some laptops, this adapter
will put the laptop's ground at a hard potential substantially
different than the car's ground. This can damage or
destroy your interface! Page 9 of Radio
Shack's own manual for this part states:
Our interfaces are
indeed "peripherals" which are powered by the car
directly!
In our opinion, the
design of this particular 12V adapter is defective.
There may be other cheap universal adapters which have the
same design defect. Damage to
interfaces caused by defective 12V adapters will not be
covered under our warranty!
If you are in doubt
about the 12V adapter you already have, there are several
ways to test for this defect, depending on what electronic
test equipment you have available. The ideal
method is connect your laptop to your car with the 12V
adapter in question (but no interface!) and measure both
AC and DC current between the laptop's ground (one of the
screw receptacles on the VGA port) and the the car's
ground. If the current is low (a few mA) then
the adapter is safe. If the current exceeds a
few 10's of mA, then it likely is not.
If you are looking for
a high-quality 12V adapter which is known to be safe, we
can recommend the the
Auto-Air
Adapters from Lind Electronics.
Product
Information
Interfaces
